Old 19-03-2010, 10:21 PM
Default Experience of isopropyl - good read (long)
http://enginehistory.org/Frank%20WalkerWeb1.pdf
Old 22-11-2012, 06:37 AM
Default Re: Experience of isopropyl - good read (long)
bump for good info
Old 07-02-2015, 06:41 AM
OLD-N-GREY OLD-N-GREY is offline
WOW, ... This demands re-reading to get it past the thick part of my ordinary brain.!!!!!
Old 11-05-2015, 12:38 AM
jmlegacy jmlegacy is offline
OK,
So basically it's too rich if used the injection configuration of methanol/ethanol?
What if he had adjusted the AFR to match an ideal Lambda?
I imagine that methanol has more oxygen content than iso alky.
I imagine that you will need a smaller nozzle for iso alky?
Isopropyl also contains a higher energy content than methanol
There is conflicting info on the internet about the octane of isopropyl.
and what is the stoich of Isopropanol?
Old 11-05-2015, 09:37 PM
Methanol: ......... 6.43
Ethanoi:............ 8.94
Isopropanol: ..... 10.28
Butanol: ........... 11.12
Pantanol: ......... 11.68
Gasoline: .......... 14.70
Old 17-05-2015, 04:07 AM
Hey richard, I had asked some chemist on Quora.com what the stoic is, the responded 11.4:1
His response:
The combustion of isopropanol is:
C3H8O +9/2 O2 = 6CO2 +8 H2O
Mol weights are 60 for IP
32 for O2
So for each mole of IP burned,60g you need 9/2 of O2 that is 9*32/2=144g
ratio is 60/144 or 1:2.4
air is not 100% O2 is is only 21% so need
2.4/.21= 11.4
No wonder they were shooting flames.
Old 17-05-2015, 12:41 PM
I got the data from here:
http://www.aquamist.co.uk/forum/alcohol fuel.pdf
Old 18-05-2015, 09:24 AM
parmas parmas is offline
Why would any use Isopropanol instead of ethanol or even methanol which are surely a better alcohol ?
Old 24-05-2015, 04:20 AM
Dust Dust is offline
Found this on another forum
http://subypal.blogspot.co.uk/2011/1...injection.html
Old 24-05-2015, 06:29 AM
Originally Posted by Dust View Post
Great find Dust ! A must read !
According to this article isopropyl is all way better than methanol.. what about the corrossion ? Is isoprpyl a winner here again ?
