Old 23-10-2013, 11:35 PM
bulldogface bulldogface is offline
Default Re: Wiring issue
well, i am sending you images right now. and am not sure, whenever soldering wire between 2 and 3 would fix it, since that problem seems to be on spot before nr. 2...more in a pic.
Old 24-10-2013, 12:09 AM
Got it. I think the high resistance is caused by a oxidised track, likely to be a short circuit and heated up.
Easy solder between the two points.
Old 24-10-2013, 07:30 PM
...aaand sure enough it worked system is purged and primed now, thanks for help, Richard.
Rich
Old 24-10-2013, 07:41 PM
That was quick?
Have fun!
