Old 20-03-2004, 02:06 PM
Sticks Sticks is offline
Your 6.2 in naturally aspirated isn't it? No turbo or intercooler?
If so, this may get a little tricky. It can still work, but you will need to use a small injector, and a throttle switch (set at 75% or higher) to activate the system.
Do you have an EGT gauge on your truck? That will assist you with your tuning, and show the results of the system a little better.
Sticks
02 Dodge 3500 5.9 Cummins, 3:54, 4x4, AFE Intake, US-Gear SD E-brake, PIF-EZ, PIF-Snow Performance W/M injection, Stage II fuel injectors
Will work for a hybrid turbo!
