Old 08-07-2008, 03:39 PM
aharrold aharrold is offline
Default will race pump supply two 10gph misting nozzles?
I found an 1/8" male BSPP to 1/8" female NPT adapter to come out of the pump with...then going to use a 1/8" male NPT to 1/4" OD tube push-to-connect 90 elbow...
plan on using 1/4" tubing from this fitting to a stainless check valve w/ 1/4" OD tube push-to-connect fittings each end...
then to 1/4" OD tube push-to-connect "y"...
then on to two nozzle holders fitted with two outside mount 10gph misting nozzles...
running straight methanol...
I know the risk of running straight methanol and it's potential effects on the pump, but have been running it this way for over a year now with a 1.0mm ERL nozzle...
my only question is will the race pump support this set-up?
if not...will a priming pump and/or pulse extender help meet my needs?
OR...is a shurflo my only option?
If I read the info here and understand it correctly, the race pump's psi rating is fine for this set-up...just not sure about the flow rate...
thanks in advance for your input on this...
al
