Originally Posted by Dust
Most turbo buick guys run pure meth and pump in the engine bay without a problem. Your tank is made to take meth, and be in the engine. Technicaly, it?s the phase change of the liquid that does the cooling, and the warmer the fluid, the easier it is for it to phase change. Is the pump near your exhaust or anything?
nope the pump is very far away from the exhaust. It's near the firewall where the windshield stands but way below. close to the ground where there's lot of air that can pass through.
when you say "the warmer the fluid, it's easier for it to phase change." so warmer meth is good for the system while it phase changes vs. colder meth? when i say warmer vs. colder i mean tank location where the meth in the can be cooler when trunk mounted vs. inside engine bay where meth in tank is warmer.
thanks.
chris b
