The pump will be mounted 2 meters away from the battery, so as I understood, I can use a 8mm2 cable to connect it to the battery ? Can I directly connect that big cable to the small wiring loom of the pump or do I have to open it and to completely redo the loom ?
As you told me I will get a 15psi check valve. The best is to mount it directly before the water jet, is that right ?
And finally for the pressure switch, shouldn't I get the 2-10bars version ? As I understand, if I have an absolute turbo pressure of 3.5bars, the water should be pushed in with at least 3.5 bars of pressure, meaning the 0.25-2bar one won't be enough ?
Thank you in advance !
