Old 19-04-2010, 11:22 PM
Default Re: Please post installation pictures of the HFS-3 here
Gengo:
Amazing how well the gauge colours matches the instrument panal in the dark!
Old 19-04-2010, 11:31 PM
Default Re: SC'd BMW E-36
Originally Posted by jmargo View Post
PVM mounted on an awesome plate that Howerton engineering fabbed up for me.
Jeff's 1.25 Gallon tank internally baffled.
Guage mounted.
More pictures as I finish up.
Super clean install! - keep them coming
Old 21-04-2010, 06:45 AM
EngineerX EngineerX is offline
Default Re: Honda S2000
This is a serious tank mount. The buffer tank below is very sensible.
Thanks, I used a 3/4" polypropylene bulkhead fittings to couple the surge tank to the main tank. A "breather" tube from the top of the surge tank to the top of the main tank would make it better. But I tested the 3/4" fitting and it's large enough to allow free flow between the 2 tanks with only a very small amount of air trapped on the top of the surge tank. I was able to tighten the fitting enough so that it holds the surge tank very well. These fittings are quite sturdy.
I used stainless steel 306 for the brackets. I stood on top of the main tank and the brackets were just about to yield. I weigh 155 lbs (11.07 St)
http://www.atlantarainbarrels.com/bulkheadfittings.htm
Old 09-05-2010, 10:38 AM
anymore updates?
