Old 05-11-2010, 07:14 AM
estorvito estorvito is offline
Default HFS-5 DDS3 V8 install ?- Turbo Suzuki samurai/tracker TBI
Hey guys. Just finished turbo setup in my samurai and have a question.
Looking to see if the hfs-5 dds3 v8 aquamist kit can be installed in a TBI vehicle.
If so.....
Where do i get the trigger signal from?
The vehicle is an 87 suzuki samurai w/ 93 geo tracker engine/ecm
Currently running 5psi/boost 93 octane.
Stock geo tracker ecu.
Joe
Old 05-11-2010, 08:15 AM
Default Re: HFS-5 DDS3 V8 install ?- Turbo Suzuki samurai/tracker TBI
Can you tell me the injector reisitanece. If you can obtain a EVXCU ponoput og the unit, I will help you quicker.
Old 05-11-2010, 08:49 AM
Thanks for the quick reply Richard.
I did find a picture of oem injector driver from a suzuki sidekick which is the same engine and ecm that im running.
http://kick-fix.com/ECU/injector-drivers.jpg
http://kick-fix.com/ECU/transistors.html
Not sure if that helps.
I will get actual results tomorrow afternoon if needed.
Old 05-11-2010, 11:13 PM
Ok Richard. I checked and
the injector resistance is 1.7
ECU pinout:
http://wire-a-zuke.services.officeli...TBI%20Wire.pdf
Old 06-11-2010, 05:31 PM
anyone?
Everything is installed except for the FIA2 and trigger wire.
So far so good. Just not sure where to get this signal from . I dont want to mess anything up.
Joe
Old 06-11-2010, 07:28 PM
Just got done wiring the kit.
Everything seems to be working like it should. Just need to adjust gauge and dds3v8.
I installed everything according to the diagram below.
http://www.aquamist.co.uk/forum/gall...S3v8/HFS-5.gif
Engine running at idle = Fuel Injection green LED on. Red LED off
Engine running rev. engine = Water injection Red LED blinks rapidly but no flow or pump activating.
Im thinking it has to do with adj to both controller and gauge?
Old 09-11-2010, 07:21 PM
BUMP..... stilll getting no trigger signal.
Anyone else have any ideas before i give up on this system? I really dont
want to go back to my old Vari-Cool setup.
Old 09-11-2010, 11:49 PM
I have been away for the last two weeks. just catching up. Sorry.
I had a look on the diagram, very nice and clear. I think the injector is driven by a "peak and hold" driver so the signal is extremely wak during the "hold" period. The "peak" period is good but only around 1mS of so. The DDS3v8 will not be able to detect those signals.
The green wire of the FIA2 should be connected to pin A17.
The HFS-5 consists of a FIA2 module, can you tell me if you can see a purple wire coming out of the FIA2 harness. This wire has an output of 0-5V, representing the 0-100% DC of the fuel injector.
Bofore we go any further, I like ot know if the FIA2 is reading the fuel injector correctly first.
Old 10-11-2010, 12:24 AM
I have another question, is side kick a addon unit to the original ECU. What is its function since the ECU can drive the stock injector anyway.
Old 10-11-2010, 10:09 AM
Ohh I see... Im sure thats where i have it hooked up. I will check tomorrow morning and get back to ya.
The kit i have, has no purple wire coming from the FIA2. Only wires are... 2 red, 2 green, 1 black, 1 blue, 1 brown.
http://www.aquamist.co.uk/forum/gall...-5+MBC+MAC.pdf
Its just like the one above ^^^^ minus the mbc +mac valve.
The sidekick/tracker ecu is whats running the tbi engine. The engine was swapped from a geo tracker.
Thanks again for all your help. I will check everything tomorrow and post the results.
Joe
