It would be difficult for the jet to screw itself shut. It is designed to be screwed down to a light-snug fit. All jets come from the factory adjusted this way.
Usually the grooves cut into the side of the brass insert(spinner) get clogged with debris. Make a close inspection of the brass spinner, even one groove clogged will make a significant difference in flow. |
thats what i thought... i tried screwing it shut manually after i soaked it in alcohol but it didnt want to so im sure there was some debris that dissolved up in the alcohol...
but i bought new nozzles anyway i tightened the old ones back with a spanner and i stripped the rubber thread that forms a seal over the stainless ITB pipe.. so i guess i may have caused a small boost leak... new ones are in and hand tightned so no more boost leak car is running perfect again need to have it logged to make sure im not overspraying cause compared to the old nozzles when the old ones were not blocked...now it is spraying alot i did 2 4th and one 5th gear run this morning and it used abot 1.5 litres or so temperature at altitude in summer : 26 - 32 degress celcius ( the initial setup and tune was done in winter and gains were set on max then) have you done any 1.8t stage 2 setups? car is set to run on mps and also idc i beleive..? my settings are threshold: 12 0 clock = 0.4 bar (on boost gauge) gain: 5 o clock failsafe: 1 o clock dim: 12 o clock thanks |
