Corrected the model year.
1. You are correct, this does not help me a great deal, I omly haver the ECU pinout section. 2. Good to know that it is connected to the battery. 3. This is also good. Re-locate the molex red and see if it makes and difference. In fact you can connect the molex red to the battery. Th ehFS-3 has its internal (=) switch controllered by the red wire of the grey harness. One thing puzzled me. Can you hear the HFS-3 on-borad relay clicking when this happen?
![]() Quote:
Thanks for changing the title. I'll try running the Molex red wire directly to the battery tomorrow. The problem I'm facing currently is that I can no longer get the blower motor to work. So I can't initiate the problem anymore. With the fan off, the HSF-3 works flawlessly. However, before I managed the break the blower fan, yes, you could hear and feel a relay clicking on the board. Richard, get some sleep. And thanks for all the help! |
