Old 17-01-2012, 01:00 AM
Tem120 Tem120 is offline
Default Re: Aquamist 2d Install ? on an FD?
Some information below, worth trying.
http://www.aquamist.co.uk/vbulletin/...ead.php?t=1979
ok so according to that , the primary works always , while the secondary works part of the time ( after the primaries reach 50% workload , NOW , does the aquamist work depending on the workloado f the injector? say 25% the aquamist throws out a preprogrammed ammount ?
but even when the secondary's activate they work at the same % as the primary's so if at I dont know what kind of measurement it uses but lets say , 1v is idle , and 6v is full throttle .. if the IDC works based on current then weather its on the primary or secondary , 3v will be 3 v on the primary or secondary .. unless there were some way to program the IDC to mate it with the injector's flow rate itself . so the secondaries at 50% load is 400 CC , and the primaries at 50% load is about 250 CC .. so it would be better to put it on the secondaries because its the one with the most flow and thus give the aquamist a better ratio .
BUT since it has no calibration .. what determinates that the secondary injectors are better then the primary since whne the secondaries are working so is the primary .. unless the fear is the aquamist will trigger because the primaries get to 50% quickly and it might stop combustion since there is little fuel . but shouldn't the aquamist only work when the car is in boost anyway?
