#11
Ok, check the relay in the trunk:
1) take a look at the thin red and blue wire underneath the relay, see if they are connected firmly into the relay base termninals. Those two wires should have 12V across it under "TST" condition. 2) If the wires are OK. check if there is 12V across the pump terminals. Leave the red cable alone for the time being. Your problem is is thre truck area
