Old 22-07-2013, 10:31 PM
leman_opc leman_opc is offline
Default Re: Gain setting issue -HFS-3
I was able to reconfirm that the controller sees the IDC normally today.
I also managed to get a linear progressive injection by setting the gain trimmer in default 1:1 position.
I can't imagine an easy way to test the pump pressure, but I'm almost 100% sure the meth injection works as supposed.
My original issue with an observed decrease in flow with gain increased was probably due to 100% FAV duty cycle already reached pretty soon on gain trimmer set both 90 degrees cw and 135 degrees cw (so actually almost no difference in these settings) and a occasional flow decrease noted.
Just for my better understanding - could you pls. confirm Richard that I got it right re. max gain setting (x4 to the actual IDC)? I can't find now where I got it from originally...
