Old 31-08-2013, 08:09 PM
Default Re: Failsafe Kicking in
what version is the HFS3?
Old 31-08-2013, 08:12 PM
jturnbull jturnbull is offline
Everything is in the default position excluding the jumper to disable the cel (DR1).
I*had it on for a good 20 seconds and the failsafe*was not*tripped.
I just disassembled and cleaned everything. Jets fav and didn't find any contaminants in the lines or valves. Put the spare jet on the windshield and it sprays as it should. Hooked the jets back up and went for a drive same issue.
Possible a bad FAV?
Old 31-08-2013, 08:13 PM
It is a HFS3-V3
Old 31-08-2013, 09:09 PM
Can you link DFS (disable fail-safe) and let me know if it makes a difference.
Old 31-08-2013, 09:35 PM
Linked DFS and no change
Old 31-08-2013, 09:48 PM
Can you pm me your phone number, may be it is easier to give you a call.
Old 02-09-2013, 10:52 PM
update, problem has nothing to do with the aquamist system.
