Old 15-03-2014, 11:58 AM
Default Re: failsafe problems
I was looking at the wrong place yesterday during your visit. Found the culprit at last. Two copper tracks were burnt, possibly by an accidental short circuit on circuit board during the recent installation on the second car. It wasn't caused by incorrect wiring. A small puff of smoke should be seen during the incident.
Luckily it only affected the failsafe as the main injection circuit is independent to the failsafe section.
See red arrows.
Old 15-03-2014, 08:30 PM
chris-mr2 chris-mr2 is offline
Default Re: failsafe problems ::cause found::
Blimey, well done how did you notice that?
Do you think i would benefit from buying a version 2 gauge to match the controller? Are there enough difference's in the gauges?
Old 15-03-2014, 08:39 PM
It was staring at me all the time, mind was in the wrong place. The top broken track (bottom picture) was covered up by a large resistor).
You don't need to change the gauge, just send it back to me, the will lower the WL. I think you should cut x1 and solder link x1.5. You might be OK with the current WL.
Let me know if if improve the system with x1.5 linked.
Old 01-05-2014, 04:27 PM
Hi richard
I will send gauge to you for update if thats ok, would of done it sooner but lost my phone with all my forum login details and email
Old 01-05-2014, 11:36 PM
Not a problem sending. I will be away for the entire next week.
Old 04-06-2014, 08:38 PM
Hi Richard
I soldered the 1.5 link to see if it helped, having other issues now, what would cause this symptom-
"S" light turns off
Blue w-injection light turns off
And yellow failsafe light illuminates
Any thoughts would be appreciated
Old 04-06-2014, 08:52 PM
"S" light is associated with the yellow flow sensor harness. Check it first.
"Blue" water injection light monitors the 12V power into the gauge - check harness and plug.
If the "S" cable is faulty, the failsafe will come on as it does not see flow.
Old 04-06-2014, 08:58 PM
Ok I thought it might be loose wiring myself so I'll check them all
With 1.5 linked bars show much earlier on gauge (5 or 6) but as boost rises bars drop down to 1 or 2??
Old 05-06-2014, 07:07 AM
Check the inline filter if you have abnormal flow.
Put a jumper link on "FDC" and tell me if the fuel duty cycle ramps up linearly.
Old 05-06-2014, 08:11 PM
Hi Richard
Sorted the light issues, my plugs were all covered in dust and not getting a proper connection.
With jumper in FDC the gauge filled up so turned the gain down slightly to show 7 or 8 bars
With 1.5 linked now I was able to turn threshold back to 12 o'clock and trim WL WH closer to each other without failsafe activating at start of spray
System is now working perfectly in all conditons
Many thanks for your help
