will do. basically, i crimped that brown wire to a new wire and soldered it onto the coil (the wire on it, was not long enough).
i tested all the voltages and it's getting voltage. i also manually jumped a ground wire to the coil just to make sure the valve was not dead and it indeed does spray out. |
