  #11
Old 14-04-2015, 02:28 PM
Grant M Grant M is offline
Ah ok, so you would use bridge ports in racing? Even turbo'd?
Have you got the new engine and setup running? How are you finding it?
I have a bridge port motor and turbo setup, everything to make it work, including your WI system. Me and my brother are combing in forces and were putting my engine setup in his 1976 trans am! �� should be quite fun but I need to change a couple of bits on the engine as it has an FD front cover on and I want to swap it back too an fc as it is using fc 13bt irons. Is it a simple job to swap them over? Just a case of unbolting? Doing that means I don't have to make a custom sump which is a pain in the arse as it takes time.
