Looking at the angle of those nozzle, it could do with every little help to improve the atomisation. Take a look of the video below:
https://www.youtube.com/watch?featur...&v=xvSNmn6A64M
Oh, I don't know what type of nozzles they are... but obviously not yours
![]() The image was photoshopped simply to show how recessing the nozzle tip would allow the cone to expand a little more before it was "folded over" by airflow within the tube. I assume that even your nozzles have the water leaving the pinhole as a solid stream which very quickly expands and breaks up into small droplets. My interpretation of this information is that the water leaving an exposed nozzle would be more likely to be folded back against the wall of the tube than the same nozzle recessed a few mm below the tube surface. However, I'm sure that you have more than likely tested this theory in the lab. And if experimentation shows that there is no benefit from recessing the nozzle tip, then I'll just use the standard adapter and try and get the end of the nozzle flush with the inner surface of the tube. Cheers... jondee86 |
