Old 20-07-2013, 09:10 AM
okkimi okkimi is offline
Default Re: Pump is activated after a while when the motor is not running
Originally Posted by inzunzar View Post
did he sent you a diagram?
Yes I did sent it.
Old 24-09-2016, 07:12 AM
Here is the wiring diagram that I sent years ago.
Connect the Aquamist red wire to the pin 8 (green/yellow wire) in orange connector in the engine bay black box where the ECU is.
http://imgur.com/a/JTJWC
This works in european models.
Old 24-09-2016, 08:07 AM
There is nothing wrong with the diagram. The red wire of the grey harness should be connected to D22.
Old 17-10-2016, 05:53 PM
Paulekas Paulekas is offline
My car does them same...
Old 19-11-2016, 11:52 PM
check your wiring.
