Old 01-11-2016, 10:37 PM
travelall74 travelall74 is offline
Default nozzle location
first time posting, brand new to the forum , i have been searching the forum for the answer and i haven't found it . i am working on a 2013 audi r6 v8 tfsi and wanted to know where i should put the injector nozzles? its a twin turbo setup i just am not sure where to put them . i have the system plumbed to the engine and wiring ran just need to figure this part out , thanks in advance rob
Old 02-11-2016, 02:45 PM
rotrex rotrex is offline
Default Re: nozzle location
I'd go direct port and place the nozzle close to the fuel injector, ideally right in front of them. Direct port works best if the spray does not have to take any turns. Always fit the nozzle on the same side as the injectors, otherwise most of the spray will only wet a part of the cylinder volume.
If you don't go direct port, things get more complicated. I'd propose you post pictures of the engine bay so we can see the inlet geometry.
Old 01-12-2016, 12:55 PM
kayleedave kayleedave is offline
Where is it?
________________________________________ ___________________________
Dissertation Proposal
