Old 27-11-2016, 06:50 AM
zoom07 zoom07 is offline
Default Pontiac G8 GT
I'm curious on how i'm suppose to wire up my ECU connector for my HFS-3 module which is these instruction in the manual
2. Signal to the grey RJ48 connector:
- Red ................. Ignition switched 12V
- Green ............. Fuel injector (-) pin
- Blue ..................MAP sensor (optional)
attached is what i believe the ECM wiring pinout but each fuel injector has its own return (-) . so are are these internally connected so i can hook it to any injector fuel control wire ?
I do see my MAP sensor Signal wire is Pin 58 so all i do is run that wire into my ecm on that pin???
just trying to figure this all out and cut cost on my installer trying to charge me an arm and a leg to do this.
ECM DATA
http://www.grrrr8.net/crazypaul/2008GTPinouts.pdf
