Old 05-12-2022, 10:00 PM
Orlando (CRE) Orlando (CRE) is offline
Administrator
Default Re: Nozzle Placement
If you are only using a single jet, keep it in its current location. The water meth will have more time to mix with the air for more even cylinder distribution. In addition, what I have found over the years is that using an extended jet, either a +5mm or +10mm, depending on the application, promotes better mixing of the WMI and the boosted air. I suspect that this is because the extended jets put the tip of the jet directly in the patch of the air.
