Old 02-12-2004, 05:20 PM
Zeitgeist Zeitgeist is offline
Default Small displacement turbodiesel info?
Hi, I've been looking for some WI info that's specifically directed at small displacement/~1bar boost turbodiesel engines. Most of the literature is either for the spark ignition or large displacement/high boost diesel truck markets.
I'm currently in the process of installing a small sidemount intercooler to my '87 Mercedes 300TD (3.0L inline six) and would like to augment with a dual stage WI setup. Is there any info out there for smaller/low boost diesel applications?
TIA
Casey
'87 300TD
Olympia, WA (USA)
'87 Mercedes 300TD OM603.96
Old 12-01-2005, 12:01 AM
Diesel engine output will benifit greatly with water/methanol mix. Methanol provide the fuel and water suppresses the onset of detonation induced by the methaol.
The exact WM % is by experiment. I worked on an industrial diesel engine recently and have found WM 87/13 ratio allows go od gain in power without detomation.
