Old 03-02-2005, 09:02 AM
ka24det ka24det is offline
Thank you for the reply,
I just learn alot of stuff on here everyday.
THank you again!
Carlos
Originally Posted by PuntoRex
Just some thoughts:
1. Temp at exhaust manifold is very high, the nozzle/hose & water in them might be heated up so high & already vaporized before injection. The upstream pump might also be affected by the high temp when the water is not flowing. (Don't tell me it's gonna be injected continuously.)
2. Anything which is added into the exhaust manifold would increase the back pressure seen by the cylinders/pistons. So VE would suffer.
3. Cooling the exhaust gas also decrease the volume & pressure we need to drive the turbine. Maybe the added water can overcome this by vaporizing during injection. But it's hard to deploy & manage.
