				I have a question, how does the traction control cut the fuel?
If it just open circuit the pulsed wire,  connect it to the TC end (fuel injector) and not the OE ECU end.
 The Racelogic traction control system taps into the ECU pos. and neg. wires for each injector between the ECU and the individual injectors. Similar to F1 TC as it first appeared in Ferrari and Williams.
I was worried about running lean, your suggested way sounds like teh best option. Will try it and advise back to this post.
Thanks Richard
Will
