Old 09-02-2004, 09:36 AM
mx5 mx5 is offline
Default Where to spray the water before or after the MAF
The jet will be mounted near the mass air flow sendor of my Miata. Which is better - to spray the water befor the MAF or after it? Will the water damage the MAF if sprayed before it?
Old 09-02-2004, 01:32 PM
Default no water on maf
You can't pass water mist through a hot wire MAF, you get an instant CEL and drop to limp mode on a subaru WRX if you do.
How I know ??
I accidently got some water in my air cleaner box while spraying down my car at the drag strip to cool things off. It ran just fine until I launched and the high vacuum in the intake pulled some of the water past the edge of the air filter. BOG stall, CEL
