Old 29-07-2005, 11:57 AM
dsmtuned dsmtuned is offline
Originally Posted by hotrod
All jets respond to pressure changes pretty much the same. If you know the pressure the jet is rated at and you increase the pressure to a higher value, the flow will increase at the square root of the ratio of the pressures.
If a jet flows 120 cc/min at 40 psi, and you increase the operating pressure to 100 psi, the flow should increase to :
sqrt (100/40) = sqrt (2.5) = 1.58 ----> 1.58 x 120 = 190 cc/min
Thanks for that Larry! Exactly what I needed.
-Craig
