![]() Quote:
Thanks Larry. Yeah I guess I could run some Bandimere 110 leaded. ![]() Here are the specs on the engine; Model Designation: Oldsmobile Starfire Ninety-Eight Wheel base: 126 Valve Location: In Head Bore and Stroke: 3-7/8 x 3-7/16 Piston displacement, Cubic Inches: 324.31 Compression ratio: 8.50 Maximum Brake Horsepower: 202 @ 4000 RPM Maximum Torque Lbs.Ft. 340 @ 2400 RPM Normal Oil Pressure Pounds: 40 I don't plan on putting more than about 1500 miles per year on this car. It's just for crusing and won't be a race car. I don't have an owner's manual, but I do have a few resources on the car. I haven't found anything other than "use the highest grade fuel available." Well that doesn't mean much considering that the fuels are different 50 years later. I'd appreciate any insight you have Larry! -Craig PS- sorry I never got that Bandi video of your car to you. My camcorder took a dump that day... |
