Old 18-04-2006, 03:00 AM
Performance Driven Performance Driven is offline
Default 2002 WRX with 2d Aquamist System
A customer/friend had us install a APS DR725 Front Mount (largest available)
and Aquamist 2d water injection System.
The STi 2.5 short block with stock WRX heads, compression around 8.8:1
running 12 degree of timing along with extrude-a-hone exhaust manifolds.
UTEC is the engine management system utilized on this car.
The previous dyno tune netted 333 whp & 340 ft-lbs @ 20 psi
the turbo spooled around 2800~2900 rpm.
and the post install tune netted 375 whp & 394 ft-lbs @ 23 psi
with 17 degree of timing. Even with the gi-normus fmic the turbo
spooled at 3200~3400 rpm.
will post dyno plots when I get back to the shop.
Ben Yang
Resident Engineer
Performance Driven Parts, L.L.C.
Dynapack AWD Chassis Dyno
Jacksonville, Fl., USA
p.904.645.5486
f.904.642.0977
sojpdp@bellsouth.net
Old 18-04-2006, 08:54 PM
This is excellent work you are doing. Looking forward to read the log.
any pictures of the install?
Old 03-05-2006, 01:44 PM
Here is the before and after dyno plots.
The final dyno pull was done after road tune.
And Delta Dash was used to measure the output.
Ben Yang
Resident Engineer
p.904.645.5486
f.904.642.0977
Old 13-05-2006, 06:39 AM
InjectedWRX InjectedWRX is offline
but what turbo?
Old 18-05-2006, 03:04 PM
I believe it is a TDO5H-18G
Ben Yang
Resident Engineer
p.904.645.5486
f.904.642.0977
