![]() Quote:
Then the 40cc accumulator is mounted 3-4 feet behind them and everything else (check valve, manifold, water pressure switch, pump) is feet away back in the trunk of the car right next to the battery. The setup was same exact one during the low IDC test too. So the HSV was right next to the jet with pre-stored pressure (accumulator too) - the pressure was whatever the 2D does at stock settings - currently I don't have a gauge to monitor it. So back to the pressure now ![]() What pressure gauge should I get? Does the Aquamist one which uses a 4mm line in a tee work fine? Do I have to take the air out of the line to the gauge, or just tap it in the tee and not to worry? |
