Old 28-10-2011, 10:51 PM
zakshaker zakshaker is offline
Default Re: max water/meth ratio you've been spraying to your engine ?
here is what I have
direct ignition difference (without compare to WI)
cell raw"P17" column"N09" is where it was 60% WM50
Since then petrol quality went down in Mauritius (it was alread bad, but it went worse 4 weeks ago) so my new map is very diferent.
I will be able to compare from single jet to 3 jets on my next mappings . the car is a TOYOTA for maintenance ATM, they will fit new jet as soon as I tell them where to fit.
I might still have datalogs maps from my previous EMS (which was an emanage ultimate), I now use a PFC
Old 31-10-2011, 10:50 AM
Thanks for the chart, it will be great to compare when you start using pre-turbo injection.
