Old 22-10-2011, 08:42 PM
zakshaker zakshaker is offline
Default max water/meth vs fuel ratio you've been spraying to your engine ?
Hello all,
I've been wondering what is the max water/meth ratio you guys have been able to spray before it starts to loose power
The reason i'm wondering this is cause I accidentaly sprayed much more watermeth (50:50) than I though it was set up for and has been able to gain better timing.
So I'm actualy spraying 31% of 50:50 water/meth mix and it looks I have room for more.
what would be downside of spraying even more ? Could I spray as much as I want until I reach the point it missfire ?
for reference : I use ATM an HFS-3 with a 1mm jet . Engine is 1348cc Turbo with 360cc fuel injector
Old 25-10-2011, 08:09 AM
Default Re: max water/meth ratio you've been spraying to your engine ?
It would be interesting how much more watermeth you can add before it blows out the spark.
Old 25-10-2011, 09:14 AM
Default Re: max water/meth vs fuel ratio you've been spraying to your engine ?
Originally Posted by zakshaker View Post
Hello all,
Some zones in the engine map I have and do use up to 60% when running WM50.
My own design CDI/Coil on plug system though. On inductive much less than that.
http://www.riceracing.com.au
RICESP > F40 > Zonda > ZR1
Water Injection Specialist
Old 26-10-2011, 06:23 AM
That's a very interesting subject indeed.
I went up to 80% WM50 (standard toyota distributor with NGK iridium grade 8 plugs)
without having any missfire.
Old 26-10-2011, 08:21 AM
Dust Dust is offline
There is a diesel Navarra YD25 now running 22 gph 1387.98cc/m. No progressive control, just on/off boost switch
You can check out his math (link to another water meth forum)
http://www.alcohol-injection.com/for...html#post17554
http://www.alcohol-injection.com/for...html#post17559
http://www.alcohol-injection.com/for...di-4-3254.html
I am using 2 gph or 126 cc/m in a 650cc engine. Can't find anything about my injector size though, so I can't show the math or percentage.
Old 27-10-2011, 10:11 PM
This is very interesting. How many nozzles are you now using and the sizes? (for the 85%)
Have you changed fuel flow or ignition timng?
Old 28-10-2011, 08:30 PM
the reason why I was spraying 80% by mistake is cause I accidentaly had the unit working as single stage while I though it was progressive. yes I did a fuel map and changed ignition timing. From what I have been dataloging. the system performed at its best when it was injecting 60% WM50. so this is my next plan
I will try to install 3 jets now
1 pre turbo (0.4mm)
1 after IC (1mm)
1 before throttle (0.6mm)
I have posted regarding preturbo jet location : http://www.aquamist.co.uk/vbulletin/...?t=251&page=42
Old 28-10-2011, 09:34 PM
can you do some before and after data logging?
Old 28-10-2011, 09:57 PM
I'm not sure I get what you mean here ?
you mean dataloging before and after changes ?
Old 28-10-2011, 10:14 PM
I was trying to see the differen from the logged data with and without water. From there, I should be able to see how mch ignition gain and how lean you can run with water injection.
