#21
what version is the HFS3?
#22
Everything is in the default position excluding the jumper to disable the cel (DR1).
I*had it on for a good 20 seconds and the failsafe*was not*tripped. I just disassembled and cleaned everything. Jets fav and didn't find any contaminants in the lines or valves. Put the spare jet on the windshield and it sprays as it should. Hooked the jets back up and went for a drive same issue. Possible a bad FAV? Last edited by jturnbull; 31-08-2013 at 08:34 PM. |
#23
#24
Can you link DFS (disable fail-safe) and let me know if it makes a difference.
#25
Linked DFS and no change
#26
Can you pm me your phone number, may be it is easier to give you a call.
#27
update, problem has nothing to do with the aquamist system.
