Old 08-04-2018, 01:32 PM
turboguy turboguy is offline
Default Re: Control board not commanding FAV to open .
I think sending the controller and FAV is the best way forward.
We never charge for repairs
Alright will do, is the address under contact us on the website the correct one?
Old 08-04-2018, 05:31 PM
Shipping address:
(write "return to manufacturer for repair" or tax will be charged. Value is $10)
ERL Ltd
Iroko house
Bolney Ave. Peacehaven
East Sussex BN10 8HF
England
T: +44 1273 581007
F: +44 1273 581555
Old 10-04-2018, 12:22 AM
Alright shipped out today, should be there Friday. Thank you for doing this, pretty stand up guy to try and fix the issue first hand, rare these days. In the package are:
(2) FAV Tees, one was just purchased from Howerton a few weeks ago, worked for a day then wouldnt flow the following day. The other is the original from when I bought the kit.
(1) Relay that theFAV Tee goes into, Im still suspicious about this piece being the problem
(1) Flow sensor turbine assembly-my belief is that this is functioning fine
(1) HFS-4 Controller unit-again I believe this to be fine
Looking forward to hearing what you find out, and again thank you for taking a look.
Old 14-04-2018, 06:47 AM
Have received and checked your controller yesterday, I cannot track down any fault.
Can you tell me where the pump is installed? Send me a few picture of your install.
Old 14-04-2018, 09:30 PM
This is the only pic I have since I pulled it out to install the new tanks.
https://imgur.com/gallery/zqRV2
The pump mounted directly under the tank. This is obviously in the trunk. I still sort of feel like it might be the relay, if theres nothing wrong with the favs
Old 14-04-2018, 09:48 PM
More findings:
1. The 2x FAV Tee is good electrically.
2. One of the two coil is open circuited, the other is perfect
3. The flow sensor is good except the disc filter is 50% blocked (unusually dirty). New filter is now in place.
4. The restrictor is OK.
The controller is good. Did you install the aquamist intank filter?
I will check the flow the the FAVs and examine the internals on Monday.
Old 14-04-2018, 09:59 PM
More findings:
Posted just now regarding the pump setup, the only pic I have anyway, but yes I did have the in tank filter installed. Any other thoughts on what would make the disc filter so dirty?
Glad the other pieces are checking out alright for the most part and again I appreciate you looking through everything.
Couple pics from engine install:
https://i.imgur.com/0QbdapN.jpg
https://i.imgur.com/jxq0MFk.jpg
Old 14-04-2018, 10:01 PM
I would like you to take the in-tank filter out and examine the cleanliness. If the in-tank filter is as bad as the FAV disc filter, I would expect this is where your problem was.
Old 14-04-2018, 10:13 PM
Replaced it with a brand new one when I installed the new tanks, then went through flushing/purging the system with 100% methanol from torco, hooked everything back up, saw flow on the sensor for a split second when I jumped SYS but nothing ever came out of the other side of the FAV. When I would unhook the 6mm side hose of the fav there would be spray from the backed up pressure since it was unable to flow through the FAV
Old 14-04-2018, 10:33 PM
Current set up
https://i.imgur.com/D2j3gho.jpg
https://i.imgur.com/I0BFkVE.jpg
