Old 14-06-2006, 08:05 PM
s4orce s4orce is offline
Default pressure switch question
What is the stock/factory pressure setting on the presure switch ? Would like to know where it is set to come on at. My installer said he didn;t mess with the factory setting on the pressure switch so he can;t remember where it is set to come on at. Thanks.
Old 14-06-2006, 08:55 PM
The pressure switch is set to 10psi.
Old 15-06-2006, 03:03 AM
If i turn the screw on the pressure switch counter clockwise one full turn what does that bring the pressure down to ? 9 PSI or ??
Old 15-06-2006, 08:43 AM
Starting from the factor setting of 10 psi, a 1/4T counter clockwise will reduce the trigger point by about 2.5 - 3 psi.
Old 15-06-2006, 04:34 PM
Sweet, thanks. Exactly what I needed to know. I turned it too far then.
Old 23-06-2006, 05:35 PM
FastAOD FastAOD is offline
I would suggest putting a guage on it and use air and a volt meter to set it exaclty where you want it....I set my meter to beep when the contact is made. So i put my air compressor nozzle into the line and slowly put air into it. When my volt meter beeps, the contacts have been made, watch the gauge and see what psi it is at.....
Founder- 1320stangs.com
89' Mustang Coupe- 10.41 @ 131 - AOD- street car, water injected
Turbo's and Water
