Old 20-01-2007, 09:21 PM
Jezz Jezz is offline
Default Using Float to Failsafe with MF2.
Can anyone tell me if there is a way of wiring up the reservoir float so that it triggers the fault circuit of the MF2?
Also, what fault scenarios can the MF2 detect when set up as per the method shown in the MF2 manual?
Many thanks,
Jezz.
Old 21-01-2007, 06:16 PM
yes, I can help you on this. If you post any aquamist related topic to the aquamist section, you will get a faster reply. I check it quite regularly.
You can wire up the float switch across the 806-162 pressure switch, Upon inject, the fault led should come on. You will also disable the pump from priming itself to destruction when the tank is empted.
Old 21-01-2007, 06:27 PM
Sorry Richard, I couldn't decide which section would be best to put it in.
Thanks for the reply.
A nice simple solution too.
