Due to the amount of water/meth I`m injecting into the engine I`ve had to fit a bigger 23l tank in the boot.
I`ve had to lay it nearly flat for space and ease of filling. Problem now is the water will slosh around during cornering etc and I need to stop this happening, there`s a primer pump fitted but it`ll still cause problems with lower water levels. Has anyone any one here experience with baffleing tanks?, even some pics would be helpfull. Can you buy foam to do the job?. Cheers, Keith.
VW Mk2 Golf 16VG60 - Mitsubishi GTO TT |
