Old 07-07-2007, 11:01 PM
MARTELMARKUS MARTELMARKUS is offline
Default need help instaling aquamist 2c system on vr6 turbo
i need help! how do i make it work? i know vr6 use motronic ecu (multi point injection)in the electrical diagram of aquamist they tell tosplice it on the injectors wire! but this seems impossible to splice injectors wire! my car run a MAF (mass air flow) plesae help me making it work!
u aint dubbin if u aint rubbin
Old 08-07-2007, 08:30 AM
The system 2c is not designed to be spliced into the car injector, but driven from a third-party ECU.
You need to upgrade it to a system2d so the injector signal is not loaded by the High speed valve.
Old 08-07-2007, 04:40 PM
Default fia2
so i dont have any other choices than buying fia2. i have a stock ECU(bosch motronic)any other way of connecting my 2c kit to my vr6 turbo.
Old 08-07-2007, 05:18 PM
Default Re: fia2
You can try parallel up with one of your fuel injector and see if it affects the fueling on that cylinder.
Old 08-07-2007, 05:26 PM
Default fia2
where can i buy this today by paypal. i would buy the fia2 now but only have paypal! and secondly, would u recommend me to tune my car on a 104 octane chip and run 94 octane(tune my car with aquamist and methanol )or just tune my car without aquamist and use it as a precaution! is it safe to tune my car with the aquamist kit to max out performance! serious dammage could occur to my engine if i tune my car with aquamist and suddenly the water jet failed. that could result in melting the engine
Old 08-07-2007, 07:49 PM
Default fia2
i forgot to say that i had high impedance injectors(14 ohms)! i already bought the fia2 this afternoon on the web. did i make a mistake.
