Old 01-09-2007, 04:24 PM
baconmotorsport baconmotorsport is offline
Default extra 4mm hose
Can someone tell me where I can get some more of the 4mm line. I am in the US and I have checked Mcmaster Carr. They have line but I do not know which one to buy. Also... is there a recommended min. max. distance for the high speed valve from the actual nozzle. I have a 2c system going on an Evo 9 with an autronic SM4. Any other words to the wise would be great. Thanks alot!!!
Old 01-09-2007, 06:17 PM
Default Re: extra 4mm hose
You should go for either nylon of teflon (Hight temperature). Make sure it is 4mm OD.
2-3 feet is fine between the jet and HSV - the delay is only about 0.3s as the 2c is a pre-pressurised system. If you are concern about the delay, just trigger the system to come on a bit earlier.
