Old 19-12-2007, 01:34 PM
Dust Dust is offline
Default MAF vs Boost for Roots blower
So the easiest way is to run off of boost, but boost is kinda an on off thing with a normal roots blower. How would the MAF signal work for setting up a progressive spray compared to a boost based spray?
Old 20-12-2007, 12:36 AM
Default Re: MAF vs Boost for Roots blower
You have two choices to meter the spray:
1. Use a Boost vs RPM mappable controller - similar to the engine management
2. Mirroring the IDC - a composite signal that contains everything. Provided the car is tuned properly.
Old 10-01-2008, 11:08 AM
PK4 PK4 is offline
I?ve got a spare, mappable AIC with rpm/ vacuum/boost inputs. Do you happen to know how iot can be converted? I know it?s been done.
Regards, PK
