Old 01-03-2008, 09:46 PM
leedpm leedpm is offline
Default Newbie with a supercharged monaro
hi all,
I?m running a 04 monaro vxr with an intercooled Magnacharger 9psi 2 bar mafless tune with 440rwhp.
As I?m a newbie to water injection I no that the engine will benefit from it once it has had a custom tune, but can anyone tell me a rough guide to the gains it will achieve, and is it really worth it.
Cheers.
Old 08-03-2008, 07:37 PM
nutron nutron is offline
9psi 2bar? Not sure what you mean by that, there's about 14psi to one bar...
Anyway, basically, if you have a setup where the air inlet pipe is getting hot then you will benifit from cooling but otherwise it will mainly be the extra fuel that will give you more power. I see and increase of 20bhp from 195bhp to 215bhp on a 1.9 diesel Vectra. I don't know if you'll see the same sort of percentage rise but you should see enough gain to make a difference.
Personally, I think you are being greedy and you should give me some of your ponies!
