Old 05-05-2008, 08:58 AM
rb20_au rb20_au is offline
Default Pre-Turbo Question
Hi guys,
I have been reading through alot of topics in here and have a few questions i couldn't work out the answers for,
I'm currently running a Nissan RB20DET Motor with a T4 turbo running around 18-22psi with a intercooler(warmer) but with alot of lag, which i would like to relive myself of.
I'm just wondering what size jet i would need to suit my application? and when would you start it injecting (what boost?), i'm using a cheap turbo for which i have a replacement here so that's no concern, also how far back in the intake pipe should the injector be situated? The pipe is probably around 40cm long at the moment, Have a SHUREFLO (sp?) 100psi pump and wiring/valves.
Main problem is a little bit of detonation up past the 19psi mark and little mid range power due to laggy turbo.
Any advise would be good.
Thanks.
Old 28-05-2008, 06:37 PM
JohnA JohnA is offline
Why don't you start with a medium-sized nozzle (say 0.5mm) injecting at a few psi before detonation starts.
Perhaps 14psi, just in case there is mild detonation at this level but it is inaudible.
Cheers,
John
www.max-boost.co.uk
