Old 26-01-2009, 12:36 AM
BOTTLEFED BOTTLEFED is offline
Default Water/Meth Tank options
I'm having trouble finding a tank that will fit my location. There seems to be a very limited size and shape of the tanks available for AI applications.
I was looking at plastic gasoline cans. These look like the same type of plastic used for W/M tanks. Would it be safe to use one of these for a custom AI setup?
I'm thinking of using a 1 or 2 gallon can.
-Tim
-97 Viper GTS-
Old 26-01-2009, 01:10 AM
Where are you located?
Old 26-01-2009, 08:04 AM
Idaho??
-97 Viper GTS-
Old 25-03-2009, 10:42 AM
belikemike belikemike is offline
Can I use my 6 liter aluminum fuel tank to store my mix in. I have it extra from my racing cart, which is no wrecked, Don't ask I have seen pictures on the net of silver tanks but I do not know if they are aluminum or chrome steel ect.
Thank you
Old 25-03-2009, 11:38 PM
Default Re: Water/Meth Tank options
-Tim
Tim,
I wasn't being clear. I was asking what car and whereyiu want your tank to be located. Most plastic is good for methanol and water. I can post a few picture of tanks that might fit, once I know what car is yours.
Old 25-03-2009, 11:39 PM
Thank you
I believe methanol attacks aluminium. Go for plastic tanks.
Old 28-03-2009, 07:13 PM
nutron nutron is offline
Methanol does attack aluminium, I just used the 25ltr plastic container the Methanol came in. I stuck it in the boot, put a hole in the lid and pushed a hose to the bottom. Then I put a few more small holes in the lid to prevent a vacuum forming and off I went. My pump is as low on the car as possible, so even the bottom of the boot is much higher, consequently it flows through very well and I only have to top it up every three weeks now.
Old 28-03-2009, 07:31 PM
This is the best method I have seen for years. :lol:
Old 10-05-2010, 09:03 AM
Kuberia Kuberia is offline
yea i will not recomend aluminium too...its "eats" whole tank.so try platic one this will help
restauracja krakow
Old 11-05-2010, 04:12 PM
thefalls thefalls is offline
If methanol eats aluminium then wont it affect the cylinder head after prolonged use of water/methanol injection?
Or does the water decrease the corrosive effects of the methanol?
Thanks.
