Old 16-03-2009, 06:58 PM
555Subbie 555Subbie is offline
Default MF2 and 2 or 4 Injectors?
Hello folks :smile:
I have a question regarding the use of number of injectors. I am building a turbokit on a Subaru Legacy 1990 and bought the great ERL MF2 Fuelmapperkit. I vill use it in conjunction with my existing stock MPFI injection to inject additional fuel at boost... :smile: Now to the question #1. as far i am concerned the engine vill need 500cc/100 Horsepower and i wonder if a should install four injectors or two injectors for smooth function?
Would be glad if someone could give me some hint
Regards
Per :smile:
Old 23-03-2009, 10:41 AM
It will depend on the location of the injectors. Normally, four is better.
Old 23-03-2009, 12:48 PM
Thanks Mate
I recon it is better with four than two injectors...i found a guy in Denmark that has built a Ford RS-2000 with four injectors and it works very good..so i stick to four
I vill place the injectors aprox 60mm above the orginal injectors and i think it would work fine
Regards
Per
