Old 16-03-2010, 02:36 PM
andernalin_junk andernalin_junk is offline
Default which nozzel i need ?
hi
can anyone tell me which nozzel i need ?
310CC injectors 25-26PSI boosting , estimate hp arount 220-230 hp
singel nozzel
hfs5 system
also how to adjust the fail safe ? how many clicks on each button ?
Old 16-03-2010, 03:25 PM
Howerton Engineering
Default Re: which nozzel i need ?
How many cylinder car and what mix will you running?
Old 16-03-2010, 03:53 PM
50%- 50% w/m
4 cylinder 1.8l
Old 17-03-2010, 02:18 AM
Looks like a .5mm jet would be the best stating point. You'll have to see once you start running how the car reacts.
Old 17-03-2010, 06:06 AM
that's what i thoght, i got the kit with 0.8 the smallest jet
anyway' the problem now is when i turn the igintiom switch on (first mode)
the pump start working and don't stop
Could be becuse there is no map/maf/boost signal ?
I want it to work thru the maf sensor, how do i do that ?
