Old 07-04-2010, 07:09 AM
flyinryanp flyinryanp is offline
Default help. where to go
got the whole system hooked up and started going through the checks. the problem is that when i put it in test mode the pump doesnt energize. ive checked power at the relay from both the battery and key, checked ground, fuse is good and in place. all of the light on the controller seem to light up. its as if the controller isnt ground to switch the relay. i put power directly to the pump it works fine.
this test fails
2. Simulating 100% injection test:
Remove the link and put it on the ?TST? slot momentarily
and observe:
- Amber led on the controller board will light up.
- Red led on the controller board also lights up.
- The yellow should light up except for the blue RJ
connector,which lights
- The water pump will start. doesnt start
- There should be full spray on the jet instantly
unless the system is not fully primed. Allow a few
seconds for the water to reach the jet. For longer
hose run installations, remove the jet first to allow
faster priming.
- Remove the link and put it back to the ?PRK?
position before you empty the water tank. If all is
well, move to the next test stage.
Old 07-04-2010, 10:43 PM
Default Re: help. where to go
My replies in Green...
Can you check if the red and blue wire below the relay has 12V across in test mode.
this test fails
and observe:
Check if the "inj" jumper is linked.
see my first comment
faster priming.
Old 08-04-2010, 12:51 AM
You wrote:
this test fails
Remove the link and put it on the “TST” slot momentarily
and observe:
connector,which lights Yellow light on the red harness should light up
- The water pump will start. doesnt start the blue wire on the blue connector should be grounded by the controller.Check the pins of the blue RJ connector
faster priming.
- Remove the link and put it back to the “PRK”
Old 08-04-2010, 01:04 AM
Can you send me a picture of underside of the controller?
Old 08-04-2010, 01:44 AM
talked to jeff at howerton thinks i might need new controller. but to answer your questions to see if he might of missed something. the red wire has power the blue wire is the ground. i ground blue wire pump start bot contoller will not ground relay to switch. the yellow light on the red harness doesnt come on. the inj link is connected. did you need a picture to see if the link on the pwm terminal is connected to the bottom of the tree termals because it is. the water level indicater works and it show s on the gauge. i also checked continuity from blue wire at relay to blue rj connector. ive also double and triple checked all grounds. the fcm doesnt click either. but the controller reconizes it there. it also passed the first test in the manual to see if connected properly. ive already contacted vivid to see about getting replacement parts but still happy to recieve more imput to make sure the fault in the system thankyou
Old 08-04-2010, 09:00 AM
Can you tell me if the yellow led is on during your test.
One more thing to check. If you unplug the water level sensor and run the same tests again for me.
Old 08-04-2010, 06:12 PM
during the 100% simulation the only yellow light on is on the board itself and user port. unplugging the water lever sensor changes nothing.
Old 08-04-2010, 11:13 PM
May be obvious was the gauge switched on?
Old 16-04-2010, 11:31 PM
That was the problem...
Old 17-04-2010, 03:46 AM
thankyou for your time and help
