Old 22-04-2010, 03:45 AM
jmargo jmargo is offline
Default HFS-3 BMW E36
Don't mind the pics I am no photographer.
3.2L motor, 12.5lbs of Boost, Vortech V2-SQ Si trim
All the bits...
Some tunes and a Howerton 1.25G tank
PVM Bracket
1.0 Jet
Howerton Trim ring
Old 27-04-2010, 09:37 PM
Default Re: Hfs-3 bmw e-36
very nice install. Like the bracket and the right angle jet.
Old 29-04-2010, 05:17 PM
Nozzles installed....
Old 04-05-2010, 10:12 PM
Just love those 90 degree banjoo fittings.
Old 23-08-2010, 05:17 AM
New stuff....Changed to a back lite LED, adding a 3rd nozzle in the SC volute.
Old 24-08-2010, 12:04 AM
very nice. You should take up photography, good pictures.
I believe you are lowering the boss.
Old 24-08-2010, 06:08 AM
That is correct.....
The height difference between tanks...and the new pump input swivel.
Old 25-08-2010, 07:31 PM
Looks like I can say I am done...for now
New adapter from Howerton Eng. As you can see it sits on top of the jet and allows provisions to feed the other two.
And the final placement. 2X 0.7 nozzles and a single 0.3 in the volute.
Old 25-08-2010, 07:56 PM
I can't stop looking through those pictures repeatly. Work of art. Nice utilisation of thise cute little fittings from Howerton.
I aslo heard youn have good success with the controller reading the tec3 ECU. What next, armed with all those cooling jets. Boost to 25psi?
Old 26-08-2010, 01:30 AM
Yes, The controller is working great !! I really appreciate the work that went in to getting the system in-line with the car.
Not sure what is on the horizon...but I am thinking maybe 17-18psi would be a good place to be.
