Old 22-05-2010, 03:50 AM
st165 st165 is offline
Default Pre turbo + pre TB setup. No fmic? help needed.
Hi everyone, i have done a lot of reading, especially the 41pages long post on pre turbo injection. So i know where i'm going so lets not start a new pre turbo injection debat ok?
My car is 1987 celica gt-four, 2.0L turbo engine. I have an hiflow 57trim supra turbo (7mgte) which flows 49lbs/min. I plan on boosting around 22/25psi. Running on premium unleaded.
I will inject 100% water, with a 250psi pump. And a solenoid for each nozzle.
The ON/OFF of the pump as well as the two solenoid will be controlled by the emanage ultimate. Turning the pump ON at a certain psi/throttle and opening each solenoid at different psi.
I would like to know what nozzle size should i put pre TB and pre Turbo?
Also, i have a large FMIC at the moment, would it still be beneficial? or can i remove it :mrgreen: (i'd love to)
Thank you!
Cedric
