Old 24-05-2010, 12:23 PM
Canonshooter Canonshooter is offline
Default Confirming ECU Connections
I just want to make sure I'm reading the diagram below correctly;
1. I am only using IDC so the MAP sensor connection to pin 6 is not required (the MAP option is not progressive, on/off only - correct?).
2. IGN-SW #2 is pin 19
3. No external engine management for map switching, so the MAP SW connection is not needed.
4. FUEL INJ (-) is pin 11
5. OE Boost solenoid is pin 27
Old 24-05-2010, 11:51 PM
Default Re: Confirming ECU Connections
My answers in Green...
This is correct. The HFS-3 can be triggered by IDC% or MAP sensor. In either case, the system will be progressive with IDC. There is any option for the H3 to be progressive to MAP sensor but require under-board modification.
Yes
Yes. This is correct. Unless you want to use this output option to trigger ECU into "limp home mode". I would stay with boost cut option #5 below.
Yes
Yes
