Old 02-07-2010, 03:31 AM
sabreofsd sabreofsd is offline
Default Flow sensor cleaning
Hello all (but mostly directed to Richard
Has anyone cleaned the small turbine inside for a Flow Sensor (806 428)?
Here is my situation:
First generation Hydramist which has been running for ~75k with no problems
I noticed that my flow was not registering
The flow meter on the DDS-3 only shows one bar (even with the POT turned all the way down) when water is flowing
What I have done:
I unhooked the hose from the jets that are attached to my intake and let it flow to the ground
ie. Pump -> HSV -> Flow Sensor -> ground
This did not give me any more flow indicated, but the water was flowing at a high rate.
I put a jet on the end just to check it with some back pressure on the hose and the jet sprayed a perfect pattern, but again, no flow was seen on the DDS-3.
In both of the situations above, the S and B lights lite up.
I took the Flow Sensor off and checked the inside and everything was still sealed well. I removed the two adapters on both ends and cleaned the filters (even though water was flowing just fine through them).
This is something very interesting: While I had the two filters off, I blew through the sensor. With a little pressure, I could not hear the turbine spin, but with a good deal, I could hear it a little.
I really think that the turbine has somehow gotten clogged up because of the above (even though the filters were pretty much clear). I did not see a way to remove the turbine.
Any idea's?
Sabre (Julian)
The P in DCAWD
www.dcawd.com
WRB 04 STI: 97.73% Stock
More info here
Old 21-08-2010, 12:42 PM
Default Re: Flow sensor cleaning
I am sorry for the late reply, just enough hours in a day to cover all posts.
Please tell me the serial number of the flow sensor. If it is below #2000, the only part that is serviceable are the two filters. The internal turbine cannot be serviced as it was press at a set depth. May be it is time to invest of a new sensor, available from us directly.
